this is a 98' lonestar mx frame.only weighs 40lbs. with sub frame.has all rubber garmets and steering stem bearing and seal.back motor mount bracket need rewelded,i have the broke peice.also needs some welding repair on guset and frame by the swing arm piviot bolt.frame is straight and has nice powder coat.i bought another frame i don't need two.ant good welder can fix this one and you can had a great aftermarket frame for cheap.this frame is set up for standard link or no link swing arm and pro peg nerf bars.these go for $2300.00 new,i'll sell for $550.00 + shipping.
Check your PM's
