What kind of riding do you plan on doing?
The j-arms arent that bad for drag racing.
I would never hit any huge jumps on the old j-arm setup but who knows?
trail riding real rough wood trails and basically just a beach. Thats what riding i mainly do
the kitis bout 150 bucks then you gotta buy arms atleast top ones so compare your cost .. it will be hard to find a frame cheaper with papers.. myself wouldnt buy a used frame without papers last thing you need is numbers to match a stolen bike and they take it from you when everything was yours but the frame...
i see frames all the time for 300 bucks with papers and cheaper with out , if i was going to buy without papers i would run the numbers first to make sure its not hot,
the extra money you spend on a newer frame is going to increase the worth of your banshee ,
say you had a 87 , now you get a 98 frame , thats a big difference in price
i wanted to know if there is a n a-arm conversion kit for my 87 banshee. How much would it cost if there is one? and can u link a site.
thanks,
Ben
I'd just buy the A-arm frame
either way you gotta buy a arms.. good luck with the project..
thanks i have got most of it apart,so when i get home from school i could get it down to just the frame. once again thanks
you are better off just buying a arm frame and switching your stuff over , thats what i did.
you can find a arm frames for a couple hundred ,
just my 2 cents
I find it easier to convert myself, but I can weld. I made my own parts from the metal store.
