Hey guys heres the deal I havd a 98 that keeps bending the #2 shift fork... The guy I bought if off of had had it repaired and took it on one dune trip when I got it it had a #2 shift fork bent..had it replaced again... Now I took it out yesterday was shifting great by the time I left it was doing it again... I just pulled it apart and found the same problem again.... Am I shifting wrong or is there something I'm missing
So no one has seen this?
My guess would be that there is a problem with the gears, if there is just a slight amount of wear on the engagement tabs on the gears they can kick apart when you're under power and bend forks, sometimes its very very hard to see that there is anything wrong.
new gears, new shift drum, detent spring, shift shaft, shift arms and the guides.. should fix it also make sure you are not over tqing the drive sproket to the shaft... if the forks are bending the gears are wanting to "pop" out. the gears have to have worn engagement dogs OR yor drum is worn and its not holdng the gear all the way in and the for is the result..
Well I tore it apart this time but spoke to the guy who replaced it the last two times... he's been working on bikes for 18 years and swears there is nothing wrong with the gears... he's recomending I replace the shift drum so I'm gonna try and pick one up and get it back 2gether this weekend..... hope it goes well.....do u think I should relace 2ND AND 6TH?
  • 3 weeks later...
well what find i was afraid of happened.... i put the bike back together with a new shift fork and drum....went out 2day asnd it bent again.....damn this is frustrating....I think you may be right master... i seen a little wear in the tabs i should of replaced them.... do you think i'm better just findin a complete gear set to drop in?
