I no this has been brought up thousands of times, but what kind of pipes do you think would be the best for my mods/future mods.
-Jetted stock carbs for now, later either 2in1 carb with 35mm, or dual 35's
-ported stock cylinders prolly .20over
-adjustible timing plate
-v force 2
-uni airfilter in stock box
It has vf reeds, pc pipes, uni filter, jetted carbs now. Let me know any input you think I should no or do.
Thanks
pick pipes for what kind of riding you do.
your pc are like an all around pipe. like a t5. should work for most setups.
you have to say what riding you do.
pc should work for about what ever you want unless your going full drag setup.
Yes I forgot to add the riding style thanks for reminding me. I ride trails, some dunes, very little mx. Mainly just around country roads, and through fields and stuff like that. Do some drag racing with friends. Just out to have a good time when I ride and go fast.
unless your rich and want new stuff i think your ok. just tell your builder what pipes you want and what you ride at you will be ok.
You should be fine for now with your current setup............
I'm runnin' T-5's and I like them a lot, but if you start dragging more and add more mods you may want to go to Shearer's or CPI's............. :thumbsup:
