blueshee03 Posted December 30, 2006 Report Posted December 30, 2006 i'd probally keep the stuff and try to pick up a 4 mill crank.then later on if you go for a cub you'll already have a 4 mill crank.but thats just my oppinion. Quote
J-Madd Posted January 5, 2007 Author Report Posted January 5, 2007 How would these cylinders work, if at all, with a new set of regular wiseco prolites, instead of 795 series? Just getting opinions, I 've filed a claim w/Pay pal for no mention whatsoever of this being for a +4mm long rod stroker. Quote
sheefreak Posted January 5, 2007 Report Posted January 5, 2007 How would these cylinders work, if at all, with a new set of regular wiseco prolites, instead of 795 series? Just getting opinions, I 've filed a claim w/Pay pal for no mention whatsoever of this being for a +4mm long rod stroker. It won't run well at all. The 795 series pistons only compensate for the long rod w/a slightly different pin position. If it is ported for a 4 mill stroke, your port timings are going to be off. You may be able to deck the bottom of the cylinders to make it run better, but IMHO, the product you purchased was misrepresented. I think I would work on a refund and start from square one. If not, you are going to have to buy a 4-mill long rod crank. Quote
J-Madd Posted January 8, 2007 Author Report Posted January 8, 2007 It won't run well at all. The 795 series pistons only compensate for the long rod w/a slightly different pin position. If it is ported for a 4 mill stroke, your port timings are going to be off. You may be able to deck the bottom of the cylinders to make it run better, but IMHO, the product you purchased was misrepresented. I think I would work on a refund and start from square one. If not, you are going to have to buy a 4-mill long rod crank. Thanks, that's what I thought. This guy hasn't responded to the pay pal claim yet, but I should have a great chance of a refund, I'd think. Quote
J-Madd Posted January 9, 2007 Author Report Posted January 9, 2007 He's disagreeing with my claim. I'd punch this mf'er in the face if I saw him. F' e-bay forever on anything. He's Chad Baker or super b(lowjob). Quote
