dirtbike77 Posted December 22, 2006 Report Posted December 22, 2006 i have a 1998 banshee t-5 pipes and silencers two into one carb set up... i just recently got down rebuilding the bike.... i removed the air box and installed a k.n filter... when i first crun the bike up it idle and ran fine.... when i drove it it ran like a raped ape... now all of sudden i came home for a minute and i left it sittin there idling i came back to go riding and the bike started bogging down.... it would take of in first but when i layed in it, the bike started to sputter and almost sound like it wanted to back fire? i checked the plugs and the werent wet? i replaced the pulgs with new ones and the same thing? the bike has no tors? Quote
Handyman Posted December 22, 2006 Report Posted December 22, 2006 1. Did you bore out the cyclinders when you re-built the top end?? 2. Did you check the air screw? should be 1 1/2 -2 turns out 3. Whats' your elevation? 4. What size jets did you out in?? Quote
dirtbike77 Posted December 24, 2006 Author Report Posted December 24, 2006 i figured out wat is was... the stator plate had become loose... and it would cause the bike to idle a lil high and break up at high speeds... once i itightened up all the way... she ran fine Quote
