Well just pulled my plugs and the left side sitting on bike is richer.the right side is tan and left side is black.the jetting is the same.310 mains,3rd clip on needle,stock pilots,with t-6 pipes,v-force 3 reeds, and k&n, (airbox lid off).By the way glamis.Would the tors not tightened all the way make a diff?Found the rich side a tad turn loose.Thanx guys,this sight rocks.
Always check your slides after you remove the tops and make sure they slide in perfect unasyn. Another cause could be a partially clogged main jet or one that has fell out.
the slides are good and the bike runs perfect.just for some reason the left side is a little richer.
So if the top wasnt screwed all the way maybe just an 8th turn loose would it be richer?sssssorry for the dumb ?.
