STOCK 98 JUST GOT IM LOOKING TO RACE A 700R RAPTOR 07 TOP END WHAT U THINK I SHOULD PUT ON
How much $ ya got, what's done to the Raptor....and please take the caps lock off.
Are you just worried about drag racing raptors or do you do other types of riding? First thing to get is pipes then go from there.
I'll take into consideration it's a stock or piped only raptor.
Get rear tires that will hook up, first. Then pipes, a good K&N or uni air filter, remove the airbox lid and get a proflow adapter.
I say get Toomey T5 pipes or Trinity Stage IV pipes. Both good mid and up pipes....for stock port motors.
Jet the bike correctly. If you buy used pipes, etc., this will all set you back 500 bucks (tires, too...don't forget) New...probably close to 750 or so.
this should put you in front of a stock raptor if YOUR riding skills are up to par, only in a drag race.
In the trails...forget it. That's 4 stroke territory unless you're gonna spend thousands on your suspension and chassis....
i race them
What does that mean? Drag Race, MX, SCORE, Baja, TT, HARE Scramble...etc?
I think I covered it...drag race with some pipes, opened up air box and jetting....you should be fine.
Forget about trails....that's their domain.
