smokin 2 stroke Posted November 23, 2006 Report Posted November 23, 2006 whats the stock gearing/ wuts the best chain and sprocket kit availble i need some new ones Quote
4strokessuck Posted November 23, 2006 Report Posted November 23, 2006 (edited) 14/41 for the gearing. In my opinion when you do replace, replace both sprockets and chain and start over fresh. Sprockets are sprockets and should last the life of the chain. For the chain, however, look for one with a tensile strength better then 7,500 lbs. I personally don't like o-ring chains because as the seals wear out, they tend to hold dirt and mud in behind the o-ring and seize the chain up. As long as you lube the chain before riding, you're good with a non o-ring chain. RK Racing Chain offers "pre-stretched" chains to ensure minimal maintenance. Primary Drive seems to be a good value and can be found at Rocky Mountain ATV*MC. Good luck. Edited November 23, 2006 by 4strokessuck Quote
smokin 2 stroke Posted November 23, 2006 Author Report Posted November 23, 2006 yes thats wut im doing is replacing it all my chain is bent to hell look in the repair section u can see where it cracked my case i guss im going to buy a case saver as well Quote
Animalman294 Posted November 24, 2006 Report Posted November 24, 2006 Yeah, I was wondering about those case saver's and if they were worth the money. I mean do they really keep the cases safe from a flailing chain...............? :beer: Quote
wesw Posted November 24, 2006 Report Posted November 24, 2006 yes i rolled one off cause a swinger wasnt shimmed correctly and the case saver saved it sure didnt hurt it by having it there. 25 bucks cheap insurance. [email protected] makes them good piece. Quote
smokin 2 stroke Posted November 24, 2006 Author Report Posted November 24, 2006 heres the kit i bought i got 15 41 http://www.motosport.com/offroad/productDe...HA;BANSHEE;1999 Quote
