I just got my bike back from the shop and they told me that the bike only turns on when you pull start it behind the truck.Im not going to be able to do this until next next weekend.I have water everywher even in my crank and they dont want to take it out.They told me just to drive it for an hour or two and then it will burn out all the water nd be fine.Is this normal????Please help me.
:banghead:
water in the oil does not just burn out thats crazy change the oil and find out why its getting in there. i think i would find a different shop to work on your bike
Yea they already did.Bike runs good now.Water got in there from last time I went mudding.It was raining and my bike got stuck fro like 2 hours in a mud hole that was covered with water. :banghead:Im never going mudding ever again
check the choke tube in between carbs.. you also might check your slides they only go in one way but they could have installed them in the wrong carb and then they will be backwards.. this will make it run like choke is on all the time and wanna bog/fould plugs...
