Ori Posted November 20, 2006 Report Posted November 20, 2006 Hi,I was woundering if anyone had and pics or diagrams of how to plumb the banshee's coolent system. Also,the tranny has a line to it to with a T-joint at the end,where do these lines go? Thanks Quote
racer Posted November 21, 2006 Report Posted November 21, 2006 i dont have a diagram, but here goes: the large hose from the head goes to the large upper fitting on the radiator. the small hose from the head goes into the small upper fitting on the radiator. the large hose from the case/waterpump goes to the only lower fitting on the rad. the short large hose goes from the head to the case, it rests between the reeds. the line from the case should have 3 lines at the tee- one to the rear of the case, one to the front and one to the atmosphere. now im gonna draw a shitty diagram in paint. Quote
