wooten Posted November 11, 2006 Report Posted November 11, 2006 ok i unplugged all the tors stuff a few months ago and this week i decided to cut all the plugs and wires out of the harness and take the black box off i cutthe wires coming from the carbs, the one wire from the throttle a black wire, and the one from the clutch side and i also cut the green and yellow wire that runs tothe back and all plug ins that went to the tors shit and now i cant start it unless i pour a little gas in to the carbs and it will only run for a min, or two and quits and will not start back what is this did i cut something i didnt need to or what also can some one please give me a pic of where the wires in the back plug in the yellow and blu wire. its a 02 model Quote
okbeast Posted November 12, 2006 Report Posted November 12, 2006 Judging by how it'll start when you pour gas in the carb but then dies, sounds like you're not getting fuel, not trying to be a smartass but are you sure the gas is on? Quote
Satsol67 Posted November 12, 2006 Report Posted November 12, 2006 Download the service manual thats on the sticky it has the wiring diagram. Hope that helps Quote
wooten Posted November 12, 2006 Author Report Posted November 12, 2006 yes the gas is on and i will try to find the wiring diagram on here thanks, still open for ideas though !!! Quote
wooten Posted November 13, 2006 Author Report Posted November 13, 2006 do the wires have to stay on the carbs even though they are not pugged in???? Quote
wooten Posted November 13, 2006 Author Report Posted November 13, 2006 ok let me see if i got this right you leave the wires from the throttle unplugged,the black box unplugge, and the wores from the carb unplugged, i had this damn thing running and took the wireand cut them off the harness and would not idle but before i cut them it did ran and idled great but i cut the wires at the carbs and left them cut so will that make a difference i need help asap this thing is really getting on my nerves Quote
