Ok, I thing that I am going to start useing some race gas. But witch one should I use?
This is what I have heard of so far
VP racing fuel
Trick racing fuel
C-12 fuel
methanol fuel
alochal fuel
nytro burning funney cars
Av gas
110 octaine
I Cant think of anymore at the time, but I am sure their is alot more. Their is even a hindoo mart down the street that sells What they say is some kinda or racing fuel right of the pump for 6.99 a gallon. Witch one to use for my baby? Price dose not mater.
I am going to have to talk to Jeff in order to know what exactly will be done to my motor for sure. I was thinking in the lines of. woods port, shaved head, lightend flywill, 4mm stroker,carbs.nology coil and wires,already have T-5 pipes,V-forec reeds, +4 timing, and uni air filter.
Also you think that setup will beet a rapter 660 with a 250 to 300 pound rider?
I am at about 170.
well first off dont run race gas if you dont need to.. there isnt any gain to running it and having a stock bike... if anything it will actually hurt your power , now assumming you need race gas so people will argue with this but here we go.
a 2 stroke dosent need leaded gas! you premix the oil for lubrication and it does just that its lubricates the motor. lead is a great additive in 4 strokes where at high rpms the motor can lack the time needed in each revelution to get alot of oil to coat the cylinder walls... and thats where the leaded fuel helps out...
just get 110 unleaded race gas and run a preimium premix and your fine...
now you listed methonal and alky, keep in mind if you want to play in the dunes you just cut your riding times in half... it takes double the fuel to run an alky bike then it does a gas bike...
Is their anything wrong with TRICK Racing Gas? The reason I ask, is cause I can get it about 3 blocks from my houes.
I was thinking caster 927 at 32:1
and about that rapter 660
A 4 mil stroker against a raptor? Hah! You will tear him a new one.. Not even the same level. :thumbsup:
VP racing fuel
Trick racing fuel
C-12 fuel
methanol fuel
alochal fuel
Av gas
110 octaine
I am at about 170.
You forgot turbo blue, it is the best race gas for banshee's up this way that we have found. it run alot better then vp c12 and c14
Edited by banshee332
