foxy30 Posted October 26, 2006 Report Posted October 26, 2006 hello, i have a 2002 banshee that runs rough,bogs in first gear -ok after that- starts usually first or second when cold. sometimes wont start when warmed up and if it does it will usually idle high .seems to be excessive smoke from both pipes.checked plugs, both are very wet.bike is completely stock except for twist throttle and no tors i run spectro gold at 40:1.carbs have been cleaned, reeds have been changed,new plugs as well. any help or guidance would be greatly appreciated Quote
okbeast Posted October 26, 2006 Report Posted October 26, 2006 What are your jets and needles set at? Quote
mavbike Posted October 26, 2006 Report Posted October 26, 2006 What are your jets and needles set at? Wet plugs usualy mean rich jetting,,,but the high idle and hard to start can be vacuum (air leak). Did it start this all of a sudden, or have plugs always been wet. Quote
foxy30 Posted October 26, 2006 Author Report Posted October 26, 2006 Wet plugs usualy mean rich jetting,,,but the high idle and hard to start can be vacuum (air leak). Did it start this all of a sudden, or have plugs always been wet. not sure new bike to me alwys ran rich with high or low or normal idle depending on temp of bike warmer it gets it has a tendency to race up in idle Quote
