K&N Clamp on
I love the K&N filters, but i had a lot of problems getting the midrange right, the bike just dont want to run with clamp on filter,great topend, but thats all, i know that if the filter or distance between carb and filter is to short or have a closed back the pulse or soundwave get reflected and interfere with the amount of fuel getting into the motor. I've put a 2 into 1 y boot system on (by frome yamaha 73-75 RD350 y boot) its really cheap its the same y boot that pro flo use, but much cheaper from yamaha, i bet they get theirs form yamaha. I can get you the part number, anyway it works great, better midrange and jetting sorted. What K&N clamp on do i have to use if i want to replace the y boot with 2 clamp on filters, any have a K&N part number. What mains and pilots will it settle more & less with pro circuit pipes?
Thanks
My spelling is not good im from SA
i don't seem to have a problem with my k&n clamp on's in the mid range, they actually worked much better everywhere in the power band... & i also have Pro-Circuits but with 28 Flat slides. i have it jetted at 310/30 & air screw tured out 1.5 turns, i'm at sea level.
http://www.kimpex.com/catalog.php?action=s...43&section=
your reeds block the back charge of the waves.
you sound like you have a jetting issue. most likely with open filter = more air you need more fuel. try raising yourneedle a clip and see how it runs.
