Ok, I rewired her today, went super smooth.
Went to start it and it would fire for like a split second(sounds like one cylindar at a time, they would switch between each other).
I have spark.
I put a Vitos +4 degree key in it recently and havent started it yet with it in.
I am thinking i may have installed the degree key in backwards causing the timing to retard rather then advance which is giving me this problem.
Wondering if you guys think the same.
Also when i rewired it I used 12 gauge wire because i had some laying around, I also took all the lights off, and the key. I just wired the key wire that comes out of the CDI to the ground.
Wondering if any of the things I did when rewiring it could cause this problem.
Thanks guys.
