IROOST1 Posted October 5, 2006 Report Posted October 5, 2006 I have my shee motor all apart and need to order a new locking washer for the clutch basket but i was wondering what type of sealant I need when i put the motor back together??? Also, are there any other parts i need to replace??? I got a good welded crank and new gaskets and new oil seals. Anything else? Good thing i did get a new crank, it ran fine and all after it sucked sand in the intake but the flywheel side two bearings sound terrible and they just keep spinnin with no resistance. Whew :geek: Quote
dajogejr Posted October 5, 2006 Report Posted October 5, 2006 Yamabond, thin layer is just fine. If the lockwasher that holds the countershaft sprocket on is worn, I'd replace that.... Quote
