Hello
I am looking for the ideal sprocket sizes for my bike.
I know the standard size is 14/41t.
I drive mainly roads and some trails so I need a good top speed.
I got douglas red label with maxxis street tires.
I don't now the sizes but the wheels are a lot smaller on the back than
the standard rims.
So i lost a lot of top speed.
The maximum is about 70mph.
I want to get to about 90 mph when possible.
My shee is practicly OEM but I'm gonna have a Noss head with 20cc domes,
a trinity stage IV exhaust, K&N pod's, right jets, dune port (probably)
So what sprocket size do I need to get to that kind of top speed, (a loss in bottom in not
important for me)?
Thx for the answers
Fred :wink:
Edited by Fre530d
Good luck...
Small tire size (I guess you got 18's) are gonna kill ya....
Here's a calculator to estimate, but it does not take into consideration if your motor can actually "pull" that gearing.
I'd say with a good strong dune port it might...but, 90MPH on an 18 inch rear tire...is gonna be hard.
You'll have to go 16/38 or so to do it...that's a HUGE gearing change....
When you say the wheels on back are smaller, do you mean the rim diameter, tire diameter???
Here's the calc:
http://home.earthlink.net/~gellett/banshee.htm
Good luck...
Here's the calc:
The rims on the back are 18" and the tires that are on them are 225/40
THX
Fred
Fred...
The majority (I'd say 90%) of riders use their shees for trail or dunes, etc.
Obviously, you live in a location that allows for street driving...
In the future, this would be helpful info to know up front, since I'd say 95% of the people that read this post would assume you meant 18inch outside diameter on the rear tires...like a motocross tire...
Just trying to help a bit...
Fred...
Thx for the help, :thumbsup:
Hello;
Puttin on a new sprocket with 17teeth today.
It goes a lot faster now and is more fun to cruise on low rpm
on the streets.
So when i use the converter I come at about 86Mph and I think
I am getting to that speed.
Not sure though,It doesn't rev quiet as high as before.
Probably not enough power?
But it's more pleasent to drive now.
When I get my trinity pipes the power will be raised a bit
so I hope it will be able to fully rev out 6th gear?
WFG
Fred
