tonelok Posted September 20, 2006 Report Posted September 20, 2006 I have a 1989 banshee and im tring to put in the push lever that is attached to the clutch cable.I need to know if there is anybody out there that can help me with this.I cant pull the old one out of its socket hows it done?HELP,HELP,HELP,HELP Quote
dajogejr Posted September 20, 2006 Report Posted September 20, 2006 I have a 1989 banshee and im tring to put in the push lever that is attached to the clutch cable.I need to know if there is anybody out there that can help me with this.I cant pull the old one out of its socket hows it done?HELP,HELP,HELP,HELP You're in a general (read, B.S. Form)...you'd get better help in the tech help section. You mean the actuator arm on the left, top side of the case? Do you have the clutch cover, clutch hubs and plates removed? I THINK, but I'm not sure, if you take the cable end off....you might be able to get it out. I'm not sure if it has pressure on it when it's unloaded from the cable.... If the cable is already off, and it's not lifting straight out, you'll have to remove the side cover, drain the coolant and tranny oil, and remove the 6 clutch spring/bolts...the outer hub should slide right off, relieving any pressure...you can leave the clutch plates/fibers in....just the outer will have to come off. you might want to get a clymers manual, you'll want to be sure that arm is adjusted properly.... Quote
