i need a little imfo, i just got a 03 banshee, it has a new hotrod crank new pistons, and has 120lbs of comp, i am running trinity 2 into 1 carb, and trinity ported cylinders, the prob. is that the left cylinder has a flat spot in it at 1/4 to 1/2 throttle if you punch the gas it runs great but if you hold the gas it just flattins out, i resealed the cylinders and intake, and i did not see that is was wet in the stator cover, if anyone has any ideals to give me i would like to here them, thanks very much,
iI'm at a loss on this one. I've got an active thread now about an annoying right cylinder issue on mine that has no answer. Ya could try replacing the plugs and gapping them both to 0.020 inches.
