i have a banshee that is smokin out of the right pipe...it idles high n breaks up on the top end. however...my carb cap is coming loose...i think that it might throw my air/fuel off n give it a air leak(obviously) if you hiit the gas it jerks the hole cap. i dont know maybe some suggestions? also i removed the components to the tors but still have the big boxes on the top of the carb...when i adjust the idle screw it doesnt seem to do much b/c i cant go all the way in so the bolt will stop turning almost like its stripped. i duno gimme some help would be appreciated.
Check to see if the slides are in sync by taking off the air filter,look down the throut and use A flashlight.Make sure they rise and fall at the same time,and have the same gap all the way down.Leave A good 1/8 in to start with then adjust both the same for desired idle.And them tors will be nothin but A headake untill you get rid of them.
