bansheefire Posted September 5, 2006 Report Posted September 5, 2006 the right side is not firing but the bike runs not like it should but it does i have cleaned carbs out checked comp switch spark plug wires clean filter and put new spark plugs what can the problem be i dont have stock carbs Quote
sheefreak Posted September 5, 2006 Report Posted September 5, 2006 Possible air leak. Do a leakdown test. If it loses more than a lb of pressure per minute, spray some soapy water around all possible leak areas and look for bubbles. Did this just happen all of a sudden, or did you have it apart for another reason and then had problems? Quote
bansheefire Posted September 6, 2006 Author Report Posted September 6, 2006 Possible air leak. Do a leakdown test. If it loses more than a lb of pressure per minute, spray some soapy water around all possible leak areas and look for bubbles. Did this just happen all of a sudden, or did you have it apart for another reason and then had problems? this just recently happend Quote
banshee0044 Posted September 8, 2006 Report Posted September 8, 2006 airleak...maybe you should plug the holes and send me my fucking crossover tube back dickhead or better yet the boost bottle you agreed to send...plus the 7$ i spent to ship it to you ... Quote
Kama Posted September 8, 2006 Report Posted September 8, 2006 If its not running at all, I would say it was some type of gas delivery since you have check most electrical (assuming you know what your doing). I recently cured an air leak in mine, and it ran but one side fired spuratically rather than not at all. I would check your carb setup and all of your jets for clogging and your fuel lines. If your carbs are running idenditcal then you will know it is a major air leak somewhere. If your not very good at troubleshooting, I suggest you take your bike to Jim Smart of Passion Racing in Tulsa (if you leave near it). I drove 2 hours to do it and couldnt be happier with the work that was done, he treats you good and does you right. He's on the forums as PassionRE, just drop him pm and he can help. Quote
