bansheefire Posted August 22, 2006 Report Posted August 22, 2006 k guys when i roll the bike while in neutral or with the cluth in the bike wont move frealy with me pushing it and i wierd gringing noise comes from the rear brake my pads look really bad do you guys think its the pads or a bent disk? Quote
Bansh-eman Posted August 22, 2006 Report Posted August 22, 2006 as you spin the wheels you will see the disk wooble side to side if it is bent.... your pads are more then likley done. Quote
bansheefire Posted August 22, 2006 Author Report Posted August 22, 2006 as you spin the wheels you will see the disk wooble side to side if it is bent.... your pads are more then likley done. would the pads cause it to grind do? Quote
Bansh-eman Posted August 22, 2006 Report Posted August 22, 2006 well it depend if there is any pad left. if not then your hitting metal on metal and thats your grinding.. also if you ride in alot of mud you might have gotten shit behind the pads and thats dragging the rotor. just spin the wheel with the bike off the ground and watch the disk if its not moving then its fine... take the caliper off and pull the two bolt that hold the pads on and check the pads. Quote
