A few things...
By hijacking the original poster's thread, which started out being a GEARING question...and you come out of left field asking about a CDI...I honestly thought you were trying to be a smart ass.
So...I left a smart ass comment as well....
That being said...even though you should post your own thread elsewhere....since you hijacked this and it is TOTALLY unrelated, there is no rev limiter on a stock CDI ...or any other 2 stroke CDI for that matter...(ok...I"m sure there may be a few out there, few and far between....)
The port design, compression, exhaust design, intake, fuel delivery and a few other factors dictate when the motor will stop revving.
Fourstrokes, however....need a rev limiter... Often they will float valves if revved too high without the proper valvetrain installed.
Hope that helps....
Thank you, that helps a lot. I was just trying to figure out the mph with the gearing chart that was mentioned above (the excel file) and one other chart I found after doing a search. I just did a gearing change and last weekend I ran the bike for the first time with that change. The bike was setup before with dune gearing and I wanted to set it up to do some road running here in Minnesota as we have no dunes here. I put my GPS on the bike when I did some testing last weekend and the mph were pretty close to what the chart said it should be with a final rpm of 9k. I went from a 14/43 to a 15/42 and it made a huge difference for road applications. I also have a 40 and I was trying to determine what the difference would be running that rear sprocket with a 15 front and still run 18" tires. You are correct in what you stated that CDI's do not have rev limits as I forgot about this as this is the first 2 stroke bike I have owned but can relate to what you say in relation to snowmobile CDI's.
No prob....typing on a board doesn't always show attitude, sarcasm or wit....It's all good.
You sled jockeys have a whole other ball to deal with, clutch engagment, cog gearing, spring rate, etc.... That's an endless loop there...but, fun as all hell.
  • 1 month later...
naaa....its 1 on the front is equal to 2 on the back. Im running 14-41 with 22" Maxxis II's for recreation, and 15-41 with the 22's for desert racing. I back down to 13-41 with 20" ITP sandstar's for the dunes, and use 20" shredders or holeshots with 14-41 for MX.
I live in Nor Cal so I need the 22" tires for clearance. Otherwise I would run 20" all the time.
Id like to try some 18" rears for MX and keep the 14-41. although I could probably go to 15-41 with 18's on and keep my speed up.
ALso.....do a search on here for banshee ben's gearing calculator. its an excel chart that really helped me see the changes in speed. and alowed me to understand gearing a little better.
where or how did i find this banshee bens gearing calculator?.thanks
It depends on what kind of boost bottle you have...
Rebel...
I'm running 14/41 now, 21 inch haulers, 72 inch rollout, starting out in 2nd for my drag racing.
I'm switching to 15/41 this weekend, and gonna start out in 1st....
i was running 15/41, but change to 15/43,and i also have a cub motor,and only sand drag.when i had 15/41 i was able to shift better,and the bike felt stronger,but i had a 43,and decided to try it,it was actually harder to shift,and the bike dint pull as hard.iam crazy for having this gearing?the guy that build my motor said to run 14/43,but i think if i run that gearing ill be even harder for me to shift?[dont have override]so i guess what iam saying is what the best gearing to your knowledge for draging up sand hills? :beer: :thanks: also i start in second gear
