20 ft lbs...
You could've found 20 posts on this easy....:)
20 ft lbs...
Just make SURE you torque them in the proper sequence, same as the factory head, use that as your guide.
I run them down snug with socket wrench.
Tighten them to 10, then 15, then 20 ft. lbs...
