Who makes the other ignition I cant remember its so frustrating its not msd, man. ALSo Im running advnaced timing plus 5 should I even bother getting a new ignition like will I even see a difference. Also I am able to run on pump gas where I am at with the plus 5 and I want to stay at premium pump gas. ANy help is much appreciated.
Don't waste your money...
280 bucks can be spent elsewhere....
Once you're looking to squeeze every last bit of horsepower out of your bike (and...pump gas ain't gonna do that) then it's an option...if you want a programmable shift light, NOS activation, etc.
I'd buy a CDI replacement from Ricky Stator if you wanted a new one, dealer will rape you for it.
I bought one because I can set my timinig plate at +8 and then play with programming curves to see what else I can get out of it...
I work for blowsion kolors I can get 114 octane I jsut dont wnat to use it pump gas is cheaper and easier
