dethinc Posted July 30, 2006 Report Posted July 30, 2006 I am selling these two machines or taking a trade on one of these for a dune buggy/sand rail if it is road legal. 2001 banshee I bought new Itp tires all around spare set of kenda claw on rims. new front plastic with a set of used rear. new bushings for a arms and wheel bearings all around. Last spring frame was powder coated gloss black, with rear swing, foot pegs .etc... motion pro tors kit. most covers are polished. dual fuel inlet for carbs. Engine this year -bored .040 installed wiseco pro lite pistons slight porting cleaning casting up. -Cylinders polished and installed new coolhead with 18cc chambers. -all new seals and bearings. -new barnett dirt digger clutch kit -new toomey t6 pipes and silencers -new sprockets with chain dropped front and raised back up one tooth, stock size chain. -new baja front bumper. -new boyseen reeds -pro flow air filter This was all done in may of this year maybe 40hrs on it now. Runs very smooth no hesitation anywhere. This machine has been totally rebuilt every year this year is the first year it had to be bored. Took our time to get this tuned perfect very snappy will rip right along. ----------------------------------------------------------------------------------------------------------------------------- 2005 blaster Was a machine i picked up from someone who did not take care of it at all. This is what has been done. New crank and bearing brand new with a new cylinder bored .040 over with a wsm piston, along with all new seals. New shift cam, was not shifting smooth. New oil injector block off New chain and sprockets New bearings in all wheels New a arm bushings New swing arm bearings New axle bearings New boyseen reeds Rejetted carb Motor has been completely redone now. A arms, front, plastic, headlight,brakes. all donated from a 1995 roller we had Machine runs great. only thing it needs is a new rear fender, has a crack under seat. Both of these machines have paper work for reg/dmv any questions email me at [email protected] Quote
