Hey, I decided to say fawk it, and keep the shee. I have a Raptor to ride while I take my sweet time to fix it up. That, and the guy never showed, so anyway. Everything I've ever owned has been a product of my back-yard engineering. I had a terrible time pulling apart the control arms because of the frozen bolts, so before I go screwing it up again,
Should I be using a torque wrench to tighten the bolts on the front end to spec, or can I just snug them. I hate braking it out, but if it is worth the extra effort, I will certianly do it. I was just wondering whtrher or not it matters, I know the nuts for the mounts have an extra ridge on them that hold them on. I also will try to grease them once a season too, they were bone dry when I pulled them last time.
Also, I will be pulling the ass end apart soon, should I be using a torque wrench anywhere there as well.
Thanks for the input!
Well, according to my banshee Clymer manual, 22ft. lbs. lower A-arms, and 28 ft.lbs. upper A-arms. These are the torque specs for the bolts that attach the a-arms to the frame.
to the frozen bolts: put some anti-seize on the metal to metal contact parts.
use antiseize on your rear pivot hardware also. youll know why when you pull it apart. :ph34r:
Awesome, thanks man, I knew they're had to be something to do for that. Unfortunately I decided to keep the stock arms, which I know is going to be a problem down the road(the ball joints were reallll stiff, and had a few rust spots here and there) So I anticipate taking it apart again if and when I get to riding it.
Any advice on whether I should tighten the nuts to spec, or just say fawk it, and crank 'em snug. Thanks!
