i hav some questions. i have a 2002 banshee and i bought it w/ fmf pipes and silencers. i was going to buy K&n pods, noss cool heads and v-force reeds. will i need to re-jet for the cool heads and the reeds. i an going to buy them at different times and i wondered if i hav to buy new jets everytime or can i buy one set and adjust them and what would it be?
You will not have to rejet fo either one the cool head has nothing to do with jetting and the reeds may richen it up but not usally enough to rejet.
I agree.
Normally...you may have to lean out the needle one clip..but, is not always neccessary...
If it's a little boggy in the middle, move the clip one notch towards the blunt end.
You will however have to rejet for the K&N Pod filters. If you're going from airbox to clamp ons, it'll be about 3 or 4 sizes larger on the main....
Jet kits are a waste of money, period.
pilots rarely change...use the air screw to fine tune.
Main jets change with mods, temps, elevation, etc.
Buy just the jets you need from carbparts.com, sudco.com or magicracing.com, or...if they have 'em and the price is fair...your local stealership...
ok, im new to this jetting thing, what jet sizes do i need for the KN clamp-on. my elevation is about 600ft. also, how do i know what sizes of jet im buying off the sites. on magic racing it says like hex head and all that stuff, but no numbers. how can u tell? sry but i dont know
Get three mains 320-340 and a 27.5pilot.When you start put the 340main in and the 27.5 pilot 1.5 turns out on the airscrew 4th clip on the needle.I know a lot of people running that with fatties and thats what i ran with my trinitys and it worked real well for me.You will need the hex mains.The size is usually in the part number.
Mikuni Mains are pretty much the same.
The pilots, however...are very different.
When you order, make sure they know they are 26mm banshee stock carbs. The pilots in those carbs are a little longer than standard Mikuni Pilots.
