njbanshee Posted July 18, 2006 Report Share Posted July 18, 2006 My bike was running great, then one day i went to race it and now the bike won't run right. It will start up on one kick, but when i hit the throttle the bike makes a wa wa wa wa wa noise and never revs up. If i let off the throttle it goes back to a near normal idle. Any ideas would be great. Quote Link to comment Share on other sites More sharing options...
ohiobanshee Posted July 18, 2006 Report Share Posted July 18, 2006 check your parking brake handlebar switch. Quote Link to comment Share on other sites More sharing options...
njbanshee Posted July 18, 2006 Author Report Share Posted July 18, 2006 I don't have one. Quote Link to comment Share on other sites More sharing options...
ellison445 Posted July 18, 2006 Report Share Posted July 18, 2006 If your close to Jerseycity, bring it out this sunday.. I will get her up and running for you. Hows the jetting? With this heat wave we got coming you might want to check your jetting, might be a little fat. I don't have one. Quote Link to comment Share on other sites More sharing options...
chase@miamiatv.com Posted July 18, 2006 Report Share Posted July 18, 2006 check your parking brake handlebar switch. i agree , aswell as that stupid thumb throttle clicker peice ........ disconect it all Quote Link to comment Share on other sites More sharing options...
feedmelies Posted July 18, 2006 Report Share Posted July 18, 2006 Something similar happened to me when I first started riding 2 strokes. When I first got my quad, I took it out and after about ten minutes it started bogging hard when I even dabbed the throttle. I think I sort of fouled the plugs because I was riding in too low of RPM Quote Link to comment Share on other sites More sharing options...
njbanshee Posted July 18, 2006 Author Report Share Posted July 18, 2006 I'm gonna f with it today and try some new ideas. I'll keep you guys posted. keep the good ideas coming. Quote Link to comment Share on other sites More sharing options...
msprouse Posted July 18, 2006 Report Share Posted July 18, 2006 yeah I am sure it is that damn park brake or throttle switch that is giving you hell Quote Link to comment Share on other sites More sharing options...
liquedfire Posted July 18, 2006 Report Share Posted July 18, 2006 well what about the tors????? and also u might have a bad coil/cdi it might be breaking down under load hope this helps :ninja: Glenn Quote Link to comment Share on other sites More sharing options...
sheefreak Posted July 18, 2006 Report Share Posted July 18, 2006 It's the TORS! Unplug the black box underneath the front left side of gas tank! Quote Link to comment Share on other sites More sharing options...
DRI4life Posted July 18, 2006 Report Share Posted July 18, 2006 or you have a stuck float in one of your carbs.. he already siad he doesnt have a parking brake.. could also be a clogged jet.. hard to say over the internet Quote Link to comment Share on other sites More sharing options...
sheefreak Posted July 18, 2006 Report Share Posted July 18, 2006 That's great. He didn't say he removed the rest of the TORS connections, or the leads that used to go to his parking brake. Besides, what would it take to unplug the box and check? Quote Link to comment Share on other sites More sharing options...
njbanshee Posted July 19, 2006 Author Report Share Posted July 19, 2006 I should have wrote this sooner, but i have aftermarket everything on the bike. I have no parking brake, i have 33 mm carbs, and i have a dyna egnition. That litttle black box on the front left is long gone. I even hooked up another dyna egnition to see if mine had failed. The results were the same. I think my next move is to take the carbs apart and inspect them. Keep the suggestions coming guys. Quote Link to comment Share on other sites More sharing options...
DRI4life Posted July 19, 2006 Report Share Posted July 19, 2006 (edited) i would suggest cleaning the carbs.. but you can try tapping on the bowls lightly with a tool and then riding it around for 10 mins.. you might get lucky and loosen something up in the carbs and it will rev up again.. i do it when my bike is acting up and it has worked before.. if you do open your carbs then take one apart at a time, dont mix any parts and remember where they go back.. and remember clean airfilters are your best friend. i have three k&n filters. i change it out after every 5-6 gallons with a clean one.. great insurance for the motor and no thats not over kill. Edited July 19, 2006 by DRI4life Quote Link to comment Share on other sites More sharing options...
njbanshee Posted July 19, 2006 Author Report Share Posted July 19, 2006 I can't ride the bike around. It idles and thats it. It will not rev at all. Quote Link to comment Share on other sites More sharing options...
