Need some help here, I got a post in over at PS too.
Nology with hotwires says their coil setup should be run without resistor plugs.
My new Dyna (just opened the box) says it needs to be run ONLY with resistor plugs.
So...whaddaya think? Of course...I just bought 4 B8EGVs at 6 bucks a pop or so...go figure.
well all i can say is that i have that same set up and i run br8es in it. i have never had a problem with it. my take on it is i would rather damage a coil or the wires with resistor plugs than to damage the cdi without resistor plugs. coil is a a lot cheaper than the cdi.
Yep...pretty much the consens I've came up with by talking to a dyna engineer over at Planet Sand.
I'll try the ol R series again....
Thanks for the info!
