Banshee runsd fine for 10 mins or so
but when it gets ot it seems to run on 1 cylinder down low
idle seems fine, maybe misfiring a tad, but down low it loses all response and runs on 1 cylinder
however when it hits powerband its fine pulls good, but a little flat if anything
so it just bogs down at low rpm at any gear, and the longer you keep going after it starts happening the worst it gets
been right through the carbies, everything is mint
only possible tihng i can think of is low speed coil in the stator
any1 else had any similar issues?
Not to be an a**hole but do a search on the boards. There have been many threads about one cyclinder not firing. Every problem has had a different solution but the steps for trouble shooting are almost the same. or the first step......look at your jetting........It would be greatly beneficial if you gave us some stats on where you are locatied and what has been done to the motor.
no probs mate
fair comment
im in perth western australia
motor is stock
only mods are k and n filter
200 main jets
not sure on pilot jet size
couldnt find much on searching, but maybe im not searching the right thing!
im pretty sure its not a fuel related problem
but you never know
no probs mate
fair comment
motor is stock
200 main jets
but you never know
Switch your plug wires and see if the problem switches also.
yeah done most of the obvious stuff, trimmed leads, checked caps, replaced plugs, carbs are mint, clean as a whistle
its only happens after 10 mins of riding which is the bit which is different to most other peoples problems
it will be fine for 10-15 mins, and the start missing down low but be fine on powerband, and as you keep going, obviously bike getting hotter it gets worst, until itll only run on 1 cylinder almost all the time
so im thinking that spark is not string enough to fire both cylinders as it gets hotter, which makes me think low speed coil?
however most of the time it will idle ok?
one occurence happened where its mainly the right side that wont run, but i watched it swap sides to the left, and fire the left at idle for a while and then it swapped back to the left
so its as if theres not enough to fire both cylinders at once when its hot? plug wire swapping seems to make no difference
