has anyone had the duncan racing mx porting done to their shee or know anyone that has had it done? if so how much power increase did you notice?
I bought a used set a few years back, excellent workmanship. I went from stock to these.Was like a whole new bike. When I went to bore them,I noticed a crack across the intake bridge. I have sinced replaced them. I'm not sure if this is comman or not,but I do know they ran really good even on the top end.
Their are alot of better builders out there than Duncan...but be my guest if you want to go spend $550 on a port job from duncan :shoothead:
what is the avarge price of a port job
All depends on the shop and the type of porting...for more mild/play ports around 200-250...mx/dune ports 300-375...that's just a guess of mine
I had the duncan Hi-rev porting and I liked it alot. They do good work but they are pricey compared to other builders. But I like my passion porting better :clap: There are a few builders on here that do very good work for less. Try a search and see what you come up.
Edited by fouledout2
