Just wondering if anyone runs stock carbs with CPI pipes and what you have for a setup. I had a motor problem a couple weeks ago and for some reason my right side piston burned up as you can see here. I was running 300 mains, 27.5 pilots and needle was at 3rd position I think. I was told that running the stock carbs with CPIs though I should be around 360 or 370 because of the way CPI's pull. Anyone that can shed some light on this so it dont happen again?
Edited by platinumjason
try 4th clip and 340 and chop the plug
it depends on your elevation and stuff most likely.
300 seems a bit lean for worked over shee.
It depends but I would say a 340 -360 would get you in a safe range and work from there.
i had stock carbs and cpi's not too long ago....my main was 340 and i was on the third clip ....i dont know what the air screw was, it was already dialed in so i didnt mess with anything but the needle :baseball_original:
Edited by r/atvshee
On my friend's banshee,I think the jetting is around a 350 or larger.Can't really remember.I know we installed a set of vito needles I had.I like the longer needles(toomey or vito).
It has a F.A.S.T. dune/play port and even with stock carbs,that banshee is very impressive.
