bansheefire Posted June 26, 2006 Report Posted June 26, 2006 after my heads are milled what is done to them do i just puttem in or what. ne one pictures Quote
BigRed350x Posted June 26, 2006 Report Posted June 26, 2006 after my heads are milled what is done to them do i just puttem in or what. ne one pictures They are basically just going to remove some material from the base of the head. Make sure its good and clean and put a new head gasket on there and re-install on your bike. DO A COMPRESSION CHECK before you run your bike and make sure you don't need a higher octane fuel. If you are below 155psi you are safe with 93 or 91 pump gas. Anything higher than that you need to start mixing race gas. Make sure you use a NEW head gasket, don't reuse the old one. Quote
J-Madd Posted June 26, 2006 Report Posted June 26, 2006 Tell him to shave it 20 thousandths IMO. That'll put it close to 150 psi. Quote
[email protected] Posted June 26, 2006 Report Posted June 26, 2006 if pedro is doing it , hell know what to do ....... hes going to ask you , you want to run race gas ? but to answer your question fully .... just read what big red wrote. Quote
