yfz350fromaus Posted June 24, 2006 Report Posted June 24, 2006 im after some info to do with gearing... at the moment im running stock size sprockets and seems to rev real hard in top gear at top speed...was wndering what sizes would be best so i dont loose to much of my bottom end power but gain a bit of top end cheers Quote
2twin350s Posted June 24, 2006 Report Posted June 24, 2006 holy crap how fast do you need to go.stock gearing should give you plenty of speed. if you are running stock rear tires or 18 inch hole shots go to a 20 inch rear tire.that will give you a little more top end.if not go up to a 15-16 tooth front sprocket,or drop 1 tooth down in the rear sprocket. Quote
sheefreak Posted June 24, 2006 Report Posted June 24, 2006 If you wan't a little more, mess w/your back sprocket. If you want a lot more go up to a 15 on the front. Moving one tooth on the front is equivalent to moving 4 teeth on the back. Therefore your fine tuning, so to speak, will come from your rear sprocket. Up for top end on the front, down for top end on the rear. If you don't have anything more than pipes, and a cool head, I wouldn't jump a tooth in the front. I would try more like maybe going down 2 in the rear. Especially if you ride sand, you will not be able to get out of the hole w/o standing on your handlebars if you go to a 15. Quote
