I just got my banshee put back together and need some advice on where to start my jetting. I have a set of .30 over cylinders with dune port, Coolhead with 20cc domes, +4 timing, T3 pipes, trinity intakes with 35mm PWK carbs running a airbox. Right now the carbs has 160 mains, 48 pilots and DEL Needles on the 4th clip. I did a plug check and my plugs looked OK. My elevation is around 1000 ft. A buddy of mine said he had about the same set up as me but he was running stock carbs and he said he didn't have a problem getting the front end up in the air in about any gear he wanted to, not haveing to clutch just gas it. Isn't the T3's supposed to be a real punchy mid range? I just thought I would ask you alls opinions.
