Samdogmx Posted June 18, 2006 Report Posted June 18, 2006 Im switching from FMF fattys to CPI inframes. Do you think I should go up one or two on the mains? or more? I was thinking of going up two & working from there. Unless you guys say otherwise. thanks in advance Quote
Hilarious Posted June 19, 2006 Report Posted June 19, 2006 What size jets do you have in there already when you were running your FMFs? I had 340's in with my fattys and when I changed the CPIs leaned the pilot and midrange circuit a little. You may need to raise your needles a bit. After you change your pipes out, do a plug test before you go out rippin it up with the CPIs. You outta notice more power everywhere. :beer: Quote
Samdogmx Posted June 20, 2006 Author Report Posted June 20, 2006 What size jets do you have in there already when you were running your FMFs? I had 340's in with my fattys and when I changed the CPIs leaned the pilot and midrange circuit a little. You may need to raise your needles a bit. After you change your pipes out, do a plug test before you go out rippin it up with the CPIs. You outta notice more power everywhere. :beer: Right now im running 350 mains 27.5 piloits the longer needles on the 3rd clip & about 3/4 turn on the airscrew. I just ordered me up some 35mm airstrikers & I'm gona be doing some porting now though, so i'll have to start all over with these carbs. LOL Quote
