cdwood37 Posted June 11, 2006 Report Posted June 11, 2006 I put in a 40 pilot today and let it idle for like 20 mins and then shut it down and checked the plugs. They were wet but they were a nice tan color on the ring and electrode but they were still a little wet, is this normal or should i drop down another size? And i need a needle that is leaner than a cel what is the next two leanest sizes? Quote
flea49 Posted June 11, 2006 Report Posted June 11, 2006 If a banshee will idle for 5 minutes without quiting you are about right or lean,I jet mine to load up and quit after about 5 minutes,I am running 4mm cub 38mm airstrykers,with 58 pilots 178 mains. Quote
