i was riding and the shee just bogged down real bad and i heard loud clunking like peices in the motor crunching and stuff..i shut it off and i kicked it, it started but no power at all and didnt idle...then i shut it off and tryed kicking it over again and it was seized up, i brought it home me and dad ripped it apart check to see if the clutch basket blew that was a negative, well we put a socket on the bottem end bolt by the clutch and turned it to see if we had compression we do but it has a dead spot it locks up and gets stuck in one part of each turn.. would that be a result in a broken Rod or what..???
Broken rod or piston, you have to tear the top end off :flamewar:
