endofitall9 Posted June 1, 2006 Report Posted June 1, 2006 just pick up some 35mm pwks with power jets installed . I have no idea what size main to put in there pilot or anything I know the stockers inside and out that's as far as it goes. the mods are; Gorr Port v-3's nosshead 21cc domes .40 prolites t3's +4 timing I will Also have K&n Pods, I know the pipes are junk. thats the next thing on the list. Besides intake boots, Will I need Reed Spacers also? 1/2 inch? Thanks for the info guys I'm at 700 above sea level. and right now the temp is 85 to 100 everyday. Quote
wesw Posted June 1, 2006 Report Posted June 1, 2006 you sure they are setup for gas, with powerjets in all??? Quote
sheefreak Posted June 1, 2006 Report Posted June 1, 2006 you sure they are setup for gas, with powerjets in all??? That's my question, sounds like they are alky carbs. Quote
endofitall9 Posted June 1, 2006 Author Report Posted June 1, 2006 yeah he said at the moment they are setup for gas but he is giving me everything to change them over to alky if I want to in the future.....I have no idea what all that is or how you convert them..anyone care to inlighten me Quote
Justintoxicated Posted June 3, 2006 Report Posted June 3, 2006 Powerjets are connected to a fuel pump right? If so my buddy has that on his Trinity banshee, and it runs on gas.. Quote
endofitall9 Posted June 3, 2006 Author Report Posted June 3, 2006 No, power jets are just another form of dial-a-jet they have a hose that runs from the carb bowl to the intake side of the carb and you can adjust your jets to the riding conditions with just a couple turns, they are gas carbs or you can run alky i have all the stuff I just don't know what size main jet to put in them so I can get them dialed in? Quote
