hey, im a newbie, been checkin out the site for awhile, lots of useful info, but i couldnt find an answer to my question
my bike is cutting out on the left cylinder when it gets above about 2500 rpms, just loses fire, i have not changed the jetting any, once it started doing it, i changed plugs, also cleaned the carbs, i have around 135 psi in each cylinder, what could it be, bad coil?? it idles perfect, just dont fire once the rpms go up, thanks for the help guys
Best way to attack it is swap carbs, and you can swap coil wires, see if the problem follows the swapped parts :clap:
just finished the cleaning the carbs, switched plug wires, same thing, what else could it be?
Air leak, le the bike idle and spray around the cyl base and intakes if it goes to stall when you spray a certain area you've found your leak
I had the same exact problem last week I wish I would have done one thing at a time so I knew for sure what fixed it.
here is a list of what i did I diconeccted all the tors electirical and cleaned the connections
I took the carbs all the way appart and cleaned them and rejetted up a size
I also took the head off and noticed that I had a broken o ring
put it all back together cleaned it and now it runs like a dream.
good luck
