badassbanshee479 Posted May 26, 2006 Report Posted May 26, 2006 need a base line for a 350 stock cylinder bike with milled head, small bore shearers and a clean up port, also running boyson reeds on stock cages, this is my play bike for now. just need a good place to start with stocker carbs. oh k&n clamp ons too!! Quote
dajogejr Posted May 26, 2006 Report Posted May 26, 2006 340 or 350 main. 27.5 pilots. Toomey (dynojet needles if you can get 'em) Stock needles have a lean spot in 'em. middle clip on stock needles, 4 clip from blunt end if you get teh dynojet needles. Air Screws 1.0 to 2.0 out. I had 330's and the above on mine..JT, with Toomeys. I'm assuming the shearers will flow a little more... I'd say 350 would be safe. Porting could make that go a little up or down...too. Good luck! Quote
