LeadBoots Posted May 19, 2006 Report Posted May 19, 2006 my left crank seal is leaking gas. the seal looks fine from the outside and the other day it was not leaking. what would cause it to leak. Quote
cdwood37 Posted May 20, 2006 Report Posted May 20, 2006 if it is leaking it is bad, the tension could have come out of the spring it could be worn who knows it it leaks then you will have to replace it. Quote
LeadBoots Posted May 22, 2006 Author Report Posted May 22, 2006 would a leaking crank seal cause hard starting when cold. its not leaking anymore so i dunno what happened Quote
cdwood37 Posted May 22, 2006 Report Posted May 22, 2006 may cause hard starting cause the premix isn't getting into the cylinder as well, check your compression you may have to low of compression causeing hard cold starting. Quote
LeadBoots Posted May 23, 2006 Author Report Posted May 23, 2006 i know its not compression left 125 and right 135 i think or the other way around Quote
