skyline_898 Posted May 17, 2006 Report Posted May 17, 2006 on my dirtbike when its in gear, i can pull in the clutch and roll it back and fourth. On my banshee i cant. I dont know if it is set up like that or if my clutch is messes up. When i drive it, i can shift fine, but i dont know if it is messed up. If it is ,tell me what to do PLZ Quote
crunk_banshee Posted May 17, 2006 Report Posted May 17, 2006 well maybe if it was not stolen it would be ok.l maybe you should get the title for it and u woujld not have to worry. so kids dont buy stolen shit Quote
skyline_898 Posted May 17, 2006 Author Report Posted May 17, 2006 hey ooba, learn how to spell and it aint stolen, i bought it negroid Quote
skyline_898 Posted May 17, 2006 Author Report Posted May 17, 2006 ur an ass... ill beat u up at skool Quote
sheefreak Posted May 17, 2006 Report Posted May 17, 2006 Could be your clutch, axle bearings, front wheel bearings.... Need more info. Is it hard to push when not running? Does it wan't to creep forward when running and you have clutch pulled in? Quote
skyline_898 Posted May 17, 2006 Author Report Posted May 17, 2006 i accidentally started in 1s gear first and it moved forward a few inches. when i am in neutral and i shift into 1st, it doesnt roll any. It is just hard to roll forward and backward when i have the clutch in. I doesnt not roll, it just resists a little bit. Quote
sheefreak Posted May 17, 2006 Report Posted May 17, 2006 Sure your brakes arent hanging up? Take the chain off and see if it rolls easy. Quote
trail rider Posted May 20, 2006 Report Posted May 20, 2006 sorry to bust in on this little argument, figured it'd be easier than to make another clutch topic. when I pull my clutch lever in, the bike still wants to roll forward and it gets worse when I rev it up. also when Im setting there (with clutch pulled in) I cant shift to neutral from 1st gear, the shifter moves fine, but its like it wont engage or something. I need a new clutch cable cause its stretched right now. and im thinking that the steel plates might be warped or burnt, which I think would cause the clutch to drag like it is. if I got a new clutch kit and cable would it also fix the problem where I cant shift from 1st to neutral, or do I need to adjust the screw thing for the shift shaft arm? and I also just got finished rebuilding the engine, new crank and topend, if this matters. Quote
