what is the best pipe for low end? i have heard that paul turners have a real good finsh. but i was wondering about the performance of them in low end. i here these are all great low end but i havnt heard much about the ct's so help me out here.
thanks
You can cut the silencer down to avoid that :cheers:
ok about the dmc's is it true that with the center mount that if you do a wheelie that the silencer hits befor the grab bar?
513498[/snapback]
Dont feel bad, Im doing the same thing with mine :D
ok what would be easier. cutting the stingers or the silencer?
im still skeptical about spending $600 on pipes and then cutting into them. i dont know about all of that
513511[/snapback]
i used t o have 916 dmc and they never touched on mine in a wheelie but then again i dont do 12 oclocks wheelies either... but wouldnt touch if i stood on grab bar to look under... only thing i had to worry bout is not having suspension to soft cus it will hit the brake caliper if it bottoms out on a big jump...
actually i never had problem but i got them used and they had a dent form the caliper .. i dont get crazy not sure how big jump was guy hit or if he even might have had a blown out shock not sure but you could tell what and where it hit... i miss those pipes they was awesome.. ran like toomeys with lil more low end power... i have pt's now would like to get dmc or t5's...
Why have you rule out fmf gnarly's.
515874[/snapback]
i havnt completely ruled them out but they are common and i wanted something a little different. btw can u get me a pic. of gnarlys on a shee?
