GSXKID Posted May 3, 2006 Report Posted May 3, 2006 Well I cant find just the crank seals any where i can only find the bearings and seals as a kit so should i just replace the bearings while its apart too. Or does anyone know where I can just get seals? Thanks Quote
GSXKID Posted May 3, 2006 Author Report Posted May 3, 2006 Thanks for the quick response. Anything else that I should replace while its apart? Im on a pretty tight budget so only things that you would think are necessary. And where would you get the bearings and seals from? I seen some on dennis kirk and i was thinking of getting them are they any good? heres a link to the ones on Dennis Kirk Quote
Big Blue Posted May 3, 2006 Report Posted May 3, 2006 You can get the entire seal kit on ebay here is the more expensive one http://cgi.ebay.com/ebaymotors/YAMAHA-BANS...sspagenameZWDVW here is the cheapo set http://cgi.ebay.com/ebaymotors/Yamaha-Bans...sspagenameZWDVW Quote
Justintoxicated Posted May 3, 2006 Report Posted May 3, 2006 I used teh K&S kit before, I look at getting new bearings but it was going to cost as much as a new crank (stock crank) so I didn't do anything as far as replacing them, If they seem fine I would not replace teh bearings unless you can get tehm cheap. But definately replace the seals. Quote
trail rider Posted May 4, 2006 Report Posted May 4, 2006 Rocky mountain atv has a bearing and seal kit by All Balls for $80 i think Quote
