It varies...based on RPM. Your stock CDI varies the timing curve as RPMs rise/fall.
Sredish had a great writeup here a bit ago about exactly how the stock timing is set and at what RPM...
510974[/snapback]
will the cdi still varie the timing when its set at +4 then?
il do a search for the write up.
510974[/snapback]
can not find the write up.
any help ?
there is...PM Sredish...he might recall the thread a little easier...
He basically lays down how much advance from the CDI from idle to 10 or 11K RPM...
