westexgt Posted May 5, 2006 Author Report Posted May 5, 2006 Thanks for the help. I am actually having hell with the fuel system right now. Using the stock fuel pump that came off the sled. Car will run for about 5 minutes, then dies completely. Wait a couple minutes and start the process over again. My banshee was doing the exact same thing keeped messing with the fuel sysytem never fixed the problem, ended up re-wiring the whole bike and putting on a new stator and not a problem since. I will pm you in a couple weeks when I get to the performance side. Kevin Quote
98bonerSTOCKshee Posted May 5, 2006 Report Posted May 5, 2006 Thanks for the help. I am actually having hell with the fuel system right now. Using the stock fuel pump that came off the sled. Car will run for about 5 minutes, then dies completely. Wait a couple minutes and start the process over again. My banshee was doing the exact same thing keeped messing with the fuel sysytem never fixed the problem, ended up re-wiring the whole bike and putting on a new stator and not a problem since. I will pm you in a couple weeks when I get to the performance side. Kevin 512273[/snapback] that looks sweet.. how much you give for it... As for never seeing a snowmobile... not much use in Texas... well it would run across the dunes.. Quote
Fireroad Express Posted May 5, 2006 Report Posted May 5, 2006 those motors like thier fuel and some came from the factory with twin mikuni fuel pumps. are you running two pumps or just one? and also, cat motors (at least older ones) are known for thier shitty stators.that might be your problem. i know that my buddies zrt tripple 800 used to go through a few and people always seem to be looking for stators for older cats , so quality was probably bad on all of them. Quote
