i finally got my cylinders back from the shop yesterday and all of the rest of my parts arrived today, so i'm ready to start putting her back together. :clap:
my cylinders seem to be kind of greasy/grimy from the honing. what should i use to clean them up before putting them back together?
any other advice for putting the new top end back together would be greatly appreciated. here's what i'm doing:
stock bore - honed, wiseco pro lites, noss head w/20cc domes, also adding v3's.
soap, water and a rag?
509314[/snapback]
well, that's what i was hoping for, very simple, but wasn't sure if it was a good idea or not. i figured if i took the air hose to it afterwards and wiped it dry too it should be ok. :confused: thanks nyuk
What NYUK said.  Also make sure you get a light coat of mix oil on cylinders immediately!  They will rust VERY fast!
509315[/snapback]
that's what i was afraid of. good idea, thanks. :cheers:
